Is EOS 3.0 compatible with a Net3 RVI? ~ Brian
Thank you for reaching out. If you can run Eos 3.0 and above on an RVI depends on how new the RVI is. There are the older RVI and the newer RVI3, and there are different generations within those products.
If you can let us know both the product and serial numbers of this RVI (to be found on a small white sticker on the back of the RVI), we can look it up and let you know. You can send this information by e-mail to eos(dot)moderator(at)etcconnect(dot)com.
