I'm using an Ion and attempting to get my moving in to a more flexible position for working live.
Here's what I've done so far. I've gone into patch and made a copy of my fixture (Elation DS575 E).
Then I took the parameters for Beam fx, Edge, and Focus and moved them into some intensity parameter
slots, I rarely use the intensity pallet. I took both gobo rotation parameters and moved them to
some shutter parameter slots since my shutters show up under Form.
This allows me to set the focus,edge and beam FX independantly of the gobo.
I built Intensity pallets with the following attributes.
Gobo Wheel 1 in focus zoomed in all the way.
Gobo Wheel 1 in focus zoomed out all the way.
Gobo Wheel 1 in focus zoomed half way.
Ditto for Gobo wheel 2
Beam Fx no prism
Beam Fx prism in no rotation
Beam Fx prism in slow rotation
yada yada yada.
It works pretty good , I can select a gobo zoom to where I want and add the beam fx, then change the gobo
without affecting any of my other beam (intensity ) settings. I can also rotate the gobo using the two
shutter parameters . Alas there is no shutter pallet.
Here's the question(s)
1. Is there a way to re-label the parameters so they don't show up in the encoder wheels as
"Frame Angle 1" , or "Frame Angle 2" when I really want them to read "Gobo rotate 1" or "Gobo rotate 2"
2. Is there any plans to add shutter pallets ??
If anyone can come up with more Ideas on this , I'd appreciate the input.
Dan
