Macro To Change Cue lists.
Hello
I have 2 cue lists one with the show's cues and one with a channel Check Cue list and I was looking to create a macro that will change the active cue list from the shows to the channel check cue list. I have played around in the macro editor and created this:
clear CMD, Go to Cue 2/1 ◆
cue 2/1 Load (being the one above the go button) ◆
And it did not change the active cue list, but what confused me is if I type that into the command line not in Maco editor it works so any help would be appreciated.
Thanks.
