Does the GIO now have the softkey buttons as real hardware buttons?*GGG*
Small side effect that confused me for a moment... Today I had a brief behavior that I've never had before.
I selected a channel, then wanted to select the intensity with the intensity button and the command line said “make manual”.
When I then pressed “Focus” I got “make abolut” in the command line.
Color leads to "flash".
When I then did SHIFT Intensity this error went away.
It cannot be reproduced and only occurred once.
EOS 3.2.5. Build 13 on a GIO
  • Check your [More SK] Hardkey. I ran into a "sometimes not working or stuck Key" a couple of times.
    Because i don't like to use the touchscreen so often for Follow/Hang and stuff, i often use the combination [More SK]+[Focus] to activate the Softkey 2. And a Stuck [More SK] or not working one is a little pain ; )
  • I agree, sounds like the console thinks that [MoreSK] was pressed.
    Just as a side note: for Follow/Hang you can use [Shift]&[Delay]
  • I have a hardware More SK button?
    (Normal i never be in this area of the desk,...*ggg*)
    For Follow/Hang i ever use SHIFT&DELAY.
  • Yes it does. To the right of the [Form] button, above [Park]
  • Park i often use.
    But above this button,...
    It is so dark, i am afraid move my fingers in this dark area,...
    Here is another funny view i get today.
    "Vorstellung" "Hersteller" "Suchen" "Edit" come from Adress/Patch.
    I was in Adres/Patch short before.
    Then switch back to LIVE and get this.
    "Scroll/Lock" solve this view so i get back the original design.
