Magic Sheet bug:
If you resize an .SVG or .PDF file in your magic sheet and then zoom in the image becomes distorted and visually shifts out of position until you zoom out, if you rotate the image and zoom in the image vanishes until you zoom out.
Magic Sheet bug:
We can reproduce this with a JPG import and will do some more research. Import dialogue shouldn't however allow PDFs. Could you please confirm which formats you're importing?
I actually only tested with .svg files. I apologize for including .PDFs I am not sure why I did.
This is now written up:
[EOS-55318]
Magic Sheet: rotated images can shift out of selection box when zooming
This has been fixed in Eos software version 3.2.6 which has released and is available for download here.
