Problem with some LED Fixtures Auto-Dimming up and down
Ion V1.82. I have had the same issue since we got the board with 1.3.6. We have 24 ADJ P56P LEDs, 2 Punch Pro LEDs, and a bunch of the Par36 LEDs. If I use the correct fixture type in patch they will start to dim up and down on their own as soon as I select any color. I can set the colors correctly but they keep dimming up and down. I have looked at all the settings for the fixture and nothing seems to change it. The only way to get them to work semi-correctly is to set them all as an Elation Opti-RGB. Am I missing something? I brought in some Chauvet LEDSplash 200B fixtures and they seem to work fine.
  • Try editing the fixture profile for the P56P led fixture. Change the Intensity minimum to 32, the maximum to 63, and the home value to 32.  The american DJ fixtures have a range of intensity effects grouped in with their intensity control parameters, which is probably causing the weird dimming as you change color. If that doesn't fix it, you may want to make your own personality for it from scratch.
    0361.p56p led.tiff
