Hi All
After installing 3.2.5 this afternoon, I loaded my current show file & noticed all the Tabs (apart from cue list & live table)
were missing.
Should the tabs info not be saved in the show file?
Many Thanks
P.
Hi All
were missing.
Many Thanks
P.
Screen layouts are not automatically preserved in your showfile. You can however save your layout as Snapshot. This snapshot will then be stored in the showfile.
[Record] {Snapshot} 1 [Enter]
To recall a snapshot because something on your screens has changed: {Snapshot} 1 [Enter]. If you mark a snapshot as Favorite (which happens by default when you record a snapshot) you can also recall snapshots from the Snapshot Popup in the top right corner:
Many Thanks,
I new there would be a simple answer.
P.
