Park
Hello
Recently I parked alot of addresses at 0% in order to try to identify what circuits I had on (please see impending post regarding non-dims) and I discovered that there seems to be only room for a certain amount of space in the Park screen to see what addresses one has parked and as far as I could see no way of scrolling through or paging down, in order to see exactly what addresses are parked?  Have I missed something? x
  • Hi Sarah.
    The paging of addresses in park is a bit unusual right now.  Typically the arrow keys will page only one section of a display.  In the case of the Park display, that would be the channel area on the top.
    The console, though, switches the paging focus when "Address" is on the command line.  Typing "Address 200 @ 0" will auto page the display to address 200.  At the point you press "Address" in the sequence, you will also be able to use the arrow keys page around the address part of the display.
    We are currently looking at options for modifying the paging of this display which will be less confusing.
    -Derek
  • Thanks very much.  That worked fine.  Was being a little blonde x
