If I have more usb devices than ports on the console, how do I connect them? Can I use a usb hub? In particular, I'm using IonXe.
Yes you can. Depending on what you want to connect an active (i.e. powered) USB hub would make sense.
I'd like to connect a second Touch Screen Monitor. The 4 USB on our IonXe are currently:
Will a passive USB Hub work fine for that?
You might also consider daisy-chaining the 2 touch screens. Keep #3 as above and then connect the second touch screen to a USB port on the first monitor.
combine the mouse and keyboard on a passive hub then that leaves a port free for your 2nd monitor
