Hello
with Gio,and IonXe and Gio@5
V3.2.4 and 3.2.5
the shutter fine mode for angle and Thrust are 100 times under the shutter resolution.
So impossible to use the fine function with shutters.
I tried 2 software versions, 3 different consoles, 3 different fixtures : Alpha Profile 1500, Alpha Profile 800, Solaframe 750 : same result
The wheel in fine mode equal +/- 0.001
the resolution in the real world for these fixtures is around +/- 0.1
Frame assembly works well
changing the wheel resolution in the setup does not works with shutters.
and in V3.2.2, the fine mode worked well too.
Thanks to fix that in the next version, we downgrade in 3.2.2 for now.
Bye
Pilou
