When exporting my magic sheets so I can print them out to help with rigs, I get a black cross hair across the images. Is there a way to turn this off?
Can you post an example of an export that shows the cross hair?
Sorry, can't work out how to upload an image! It's been a long day...
Hopefully this link will work, if allowed:
https://drive.google.com/file/d/1l1l0Yqmwbt4NuGQnqW-RtMA1C-zwMYZi/view?usp=sharing
Are you exporting from the Edit mode tollbar? Or from the gears menu?
Toolbar in Edit mode:
Gears menu:
I can see that you get the crosshairs while in Edit mode (because the crosshairs are visible at that point), but not when saving the screenshot from the gears menu, because that automatically means that Edit mode is closed. I'd consider this expected behavior.
I was exporting via the Edit menu yes. Thought the Gears menu screenshot would have saved the entire screen.
Thanks for explaining.
