Hi there,
in my showfile (Eos Version 3.2.5 Build 13) the Grp/Assert Button does not work, if the sub won't be at 0 percent. See showfile magic Sheet 1 or Tab 28 for own testing.
Kind regards
Hi there,
Kind regards
The reason why the button has two names is that it has two functions. When at 0 it selects the channels in the sub ("Group Sub x), when above 0 it asserts.
If you want the selection no matter the level of the fader you can choose the Group Select button behavior in fader config.
Oh, ok, than sorry for claiming ;) and thanks
