Is there a way to lock Magic sheet objects while in edit mode?
Thank you for helping!
Francesco
Francesco
If the object you're trying to lock is an image (e.g. a light plot) you can instead use it as background. This will make it unselectable and immovable. Other than that there is no locking for objects.
Thank you for your reply. I'm referring to the objects. Do you think could be a possible feature request?
Of course, can't hurt to ask: Feature Requests
When requesting be precise: what do you expect? Should a locked object just not move, not be selectable, no changes of properties?
