Bug Report: Ambiguous group copy/recall behavior
Expected Behavior:
Copying from a selection to a group should only copy as many lights as are in the target group, whether or not the source group contains additional lights.
Actual Behavior:
Copying from a selection which contains more lights than the target group results in additional target lights being selected.
Steps to reproduce:
Record a group, say 10 with a single light in it, say channel 101. Set values in channels 1-10 then 1-10 [copy to] [group] 10. You will note that values have been copied to channels 101-110 rather than just channel 101. The same behavior occurs if you do group recall from selection rather than copy to.
Notes:
I've noticed this behavior across several show files on an Ion Xe20 and an Eos Ti on all 3+ versions of eos, have not tested on Eos 2.9.
