Submasters+cue lists release command
Hello
Maybe someone will find the question amateur ,but is there any command to release all the runnung submasters at once plus the cue lists?
Like Go To Cue Out, but which will include the submasters as well? Like master Out command? Thanks
  • [Sub] [Home] [Thru] [Home] [Enter]
    Sub Home will insert the number of the first sub, Thru without a number will select everything to the end. And Home Enter sends all the previously selected subs to their home value.
    If you want to not only send subs to their home values but also other types of faders you can use the following syntax:
    [Fader] [Home] [Thru] [Home] [Enter].
    NB: This does not include [GoToCue] [Out] [Enter] which you'll still have to type seperately.
