Editing Moving Light Profiles
Ok... Tried looking for this in the manual with no luck....  maybe I missed it....
I have several AutoYokes in an upcoming show, however the current autoyoke profile doesn't have a "scroller" just, Dim, P/T, iris and focus.  Is there a way I can copy a profile, edit it, then save it as  a custom?
many thanks in advance.
  • M
     At this point, with released code, that is not possible.  What you can do is add a scroller to the channel.  The syntax for this would be (Channel)[n] [Part][m] [Type][Generic Scroller] [At] [y].  The behavior on the desk will then be what I believe you are looking for.
    In 1.2 (really soon) ther is a basic editor, but you will not be able to copy an existing fixture.
     Good Luck,
    John Hessler
  • jhessler:
    Just being a devil's advocate, but why not?
    Kevin
  • Kevin. that is actually in the plans, along with being able to change the default/home positions for existing library data.  We will bundle all of that into one bit of software.   Can't give you a date yet, but it is getting higher on the priority list!
    a
