I have noticed the following behaviour: I wanted to update the last cue and the current one. So I typed
[Update] [Last] [+] [Cue]
which, to my suprise, terminated the command.
Is this supposed to happen?
Thank you for bringing this up. I can see this happening all the way back to at least 2.9. I will look into it and report back when i know more.
It appears to have nothing to do with updating. Typing: [Cue][Last][+][Cue] self-terminates.
If you type: [Cue][Last][+]# it works, but then you'd have to look up the current cue number (and it does not hurt to check if you are updating the right cue does it? ;-) )
