I want to force a Cue to an aromatic blackout
Basically there is cue recorded with one channel (LED light) that is running an effect on it. The following cue after it need to be a hard/snap to black essentially. However, when I go on to the next cue it almost like fades away to black even though the value of the channel is set at zero, and the effect is at zero(stop). In the MV column the “L” is showing and I think that’s the problem. I even put a Block on the blackout cue but it’s still fading out every time I run the cue. I am wondering if there is a way to remove the “L” or a manual way to force it to go straight to black…any thoughts or suggestions?
