updating subs in 1.8 (maybe 1.9)
Hi again.
Can someone confirm this for me?
[Update] works differently in 1.8 for submasters than it does for cues, correct?
If I [Update] an I-Master sub, and that sub is referencing Beam palettes and Focus Palletes, I don't get the same options of updating all (palettes, presets), making absolute, or breaking nested.  Is this true, or I am crzy?
Does the new 1.9 [update] screen affect subs the same way it does cues?
If I have an I-Cue unit in position as set by an I-master sub, based on a FP, and I move the focus postion over, I can update the FP, but the data is still in red in the channel display.  If I [Sneak], the focus will move back to the original FP position.  If I run the sub down and up, the new FP will take command.  will  Asserting the sub also fix this?
Has this been modified in 1.9?  (I will upgrade, I just need to find the break in the schedule to do it).
Thanks.
