One of the dimmer racks is using sensor+ sinewave dimmer modules, is it possible to replace the modules with new D20AF ?
See limited capability in a Sensor+ rack https://support.etcconnect.com/ETC/Power_Controls/Dimming_Modules/Thru_Power_Module_Compatibility
The Sinewave racks have diffrerent wiring inside - they do not share neutrals and must have the hot and neutral for each circuit landed on the dimmer lugs. The sinewave modules are also a different form factor.
So the short answer is no, D20AF are not able to be installed in a Sinewave rack.
