In focus session, I put channels 29 thru 32 @ Full, then 51 thru 56 @ Full RemDim, then 27 thru 32 @ Full RemDim
It miss 27 and 28 in my selection.... (see command line and live tab in attached pic)
Am I missing something? (version 3.2.8)
Channel selection is modified by Flexi state. Change to flexi all, patched, or selected, or use 27 thru thru 32 to select all intermediary channels regardless of flexi state.
Thanks, I was blinded by the fact that my first frame was in flexi patched but because second frame was selected it couldn't work
Yep. Storing which frame should be active is imperative when recording snapshots because of this.
