Macros And Submaster
Hi All
Ive Got Quite A General Understanding Of EOS And Know Quite Abit But Im Not To Sure If I Can Set Macros As Submasters Either Bump Or The Fader.
TIA
  • You can set the Buttons as Macros.
    I would recomment to set your Macros in the Fader Config Tab (Tab 36)
    Here you can Click or Tab on the desired Button and select {Macro} from the Drop-Down Menu and after that set the Macro-No
    An other option could be in the Blind Submaster Tab (Tab 15)
    Here you can also select the Button of you choise and go on like above mentioned.
    Hope that helps.
