3.2.8
Shift+Full or Shift+Out flashes the selected channel(s) on or off. This also happens if your in blind which took me surprise. channel syntax in blind shouldn't affect live, should it?
thx, ueli
3.2.8
thx, ueli
Flashing is ephemeral and not stored anywhere, what else would you expect to happen? Nothing? I can see this very useful, IE I'm in blind, "What channel is this?" and I can flash it from where I am and get that answer.
You two have a point.
But i would rather go with ueli and say in Blind nothing should go into Live.
While in blind do you also think go to cue shouldn't work?
Thank you for reaching out. I have started a discussion with the team and will update this post when we have an answer.
Was there an answer on this? I think this is illogical behaviour, certainly when you think of how EOS is taught. Its also 'manual data' (Its red!!) so you shouldn't be able to have it in blond. If your going to keep it make it appear as override data maybe?
You can also flash outside of your partition. This I can see being useful but its mainly dangerous.
More settings are bad, yes. But make flash a set of settings under manual control (Enable Flash in Blind & Enable Out Of Partition Flash)
