Update and manual values- EOS 1.9
EOS v 1.9 build 54
Our board op has noticed that some parameters on multi-parameter fixtures that have manual values do not get released after an update command.  This may be related to:
RND 0011823 updating cue out of sequence not releasing manual levels when it should
but it is occurring when updating the current cue.  Update is set to "Update all" with no modifiers.
The manual parameters are not released by a [sneak] command from an empty command line- you have to select the specific channels and [sneak] them to get the manual values to release.
I am unable to replicate this offline from a blank show file but will have the board op note details the next time it happens on the console.
-Todd
