Submasters reseting Moving light parameters
Hey
I ran into this issue last time I was running a show off from Subs on an ION (running 1.9). I had some moving lights doing a routine using presets and effects, this worked fine till I wanted to change a submaster. When I changed a submaster the movers homed everything, color, position, gobo. I tried taking the moving light values out of the Subs in blind, but that didn't help. Not sure if anybody has run into this issue before or not, hopefully it is something easy that I am overseeing.
