Where is the close Module softkey? I am trying to get rid of a 5x20 DS Module on Screen A and Can't seem to get rid of it. Also Once that is gone. I can populate above the CIA anything correct? So tabbing my live channel to Screen A?
I don't think there is a softkey to close a module. You can however close a module the same way you open one in the "Virtual Controls" in the Displays screen. Along with the 5x20 virtual control, there is a close screen or close module I cant remember which in there.
IIRC, does the escape key not close a module? click on the Tab on the screen then press Escape?
J
I found it. I t was just eluding me. Close Module is the last option in the virtual control menu.
Escape will only close tabs not Modules.
