Is there a way to display the last received OSC message as an item on a magic sheet? I would be guessing a command of sorts, but I haven't figured out know what the syntax would be.
Are you trying to look at an incoming OSC message for diagnostic purposes? The simplest way would be to open Tab 99 (keep Tab pressed, type 99 and then release Tab). To see incoming OSC in this tab you will have to click the respective button (note that this button only affects OSC being displayed, it does not enable or disable receiving of OSC).
Essentially I'm wondering if there is a way to display that information on a magic sheet.
The Eos software doesn't have any way of duplicating the functionality of the diagnostic tab in a magic sheet.
