I'm kind of new at this, and I may not be running the most up to date software on my Ion, but I need to run some Mac 2000 Washes and they're not in my fixture library...what are my options?
Hi there. The 2K washes are in 1.9.... I didn't go back to check when they were added, but they've been in the library for quite a while. The best option is to upgrade to 1.9 software. If that is not possible, you can build your own profile via the fixtures button in patch. You'll need the DMX map from the 2K manual.
Hope that helps.
a
