Bug? Using an inhib sub on a geyser causes the geyser to fire instead of be inhibbed
Chauvet P5, P7, and RGB Geysers all fire when an inhibitive sub is brought down. In sACN Output Viewer, you can see the lowest the dmx value goes to when the inhib is in use is 10. If the fog output is already at 0, the dmx value will change to 10 as soon as the inhib starts to move down. I would expect an inhib to stop the fog output, not fire it.
