When using Query Keywords, where do the keywords come from? I can't seem to find them in Patch.
I ask because I discovered that if I patch an unpatched channel to an address, or give it a label, then it automatically gets assigned the type 'Dimmer' and the keyword 'Luminaire Incandescent', however if I take an unpatched channel and assign it the type 'Dimmer' manually, then it gets assigned the keyword 'Luminaire', resulting in a separate entry under Query->Keywords. This persists even if I then assign a label and/or address to the channel. Querying by type 'Dimmer' selects both channels, so I don't know where they're getting their keywords from.
