Is there a way to delete a mark from a cue. Stuff is marking when it is not supposed to and I cannot get them to clear. Is this possible?
Using referenced marks? You can lift channel marks by using the 'mark' button in live on the marked channels and then updating.... so you can remove the mark flag in blind by selecting the "R" cue, selecting the channels and using the 'mark button.
If they are marking in the wrong location, you can also select the channels in the "R" cue, press [mark] and then specify the cue you want them to mark in.
If you are using automarks, you can disable the function on a cue or cue part basis. So, if you have some lights that need to mark and other than you don't want to mark, place the channels you don't want to mark in a part and then disable automarking on that part.
Hope that helps.
a
