Does anyone know what size screws I need to replace the 3 screws on the bottom at the front that you loosen to open up the desk? 2 of mine have lost there heads are are difficult to undo/tighten.
Hi Matt,
one of those three screws on the bottom is ETC Part Number HW274
with following description: "SCR 6-32 X 3/8 Ph FH".
6-32 is the thred size
3/8th of an inch being the length.
PH meaning philipps + type
FH meaning flat head
Its a common screw that you should be able to source locally or
get through your ETC Dealer.
Taken from our support article, here is also a guide how to open your Ion, if you haven't come across it yet:
https://support.etcconnect.com/ETC/Consoles/Eos_Family/Ion/How_to_Open_an_Ion
Thanks Corey, exactly the information I needed.
