probable bug: fixture editor "amber" only 2 terms
Eos Nomad 6144
programming wing
faders wing
Intel Nuk 32 gb ram i7
Eos 3,2,8,25
Hello ETC Team,
in the fixture editor there are only 2 "amber" terms, it's impossible to have more than 2 cells with amber :
others color many terms, UV for example:
regards
Giovanni
  • If you work with multicell Fixtures, each Cell can use the same Amber, because they are seperated by a Cell.
    You may have a look at an other Multicell Fixture to understand and reuse it.
    Maybe use a Martin Wash XB or GLP x4 to learn from.
  • I'm Sorry , I gave a wrong example; i solved easy,doing a multicell fixture with 3 cells, obviously, but the question isn't this!
    If one people want made a standard fixture (no multicell) he can't because there are only two amber terms.
    The question is, why i have many many UV terms ( usually less used than amber in the fixture), and only two amber?
    you have:
    RED 1,2,3,4,5,6,7,8,9...
    GREEN 1,2,3,4,5,6,7,8,9...
    BlUE 1,2,3,4,5,6,7,8,9...
    WHITE 1,2,3,4,5,6...
    LIME 1,2,3,4,5,6,7...
    UV 1,2,3,4,5,6,7...
    AMBER 1,2 !
    I hope that my the explanation is clearer now!
    regard
    Giovanni
