ION Pallets
On the Ion-how does one configure to see more then two sets of 5 x 10 Direct Select Modules? is it possible to record a macro on like say a color pallet that would take you to say the Beam pallet module? i guess i am trying to find the easiest way to navigate through the direct select modules. thank you
  • With Snapshots now available on the Ion, you can record a seperate Snapshot for each of your Direct Select pages, therefore being able to have a Beam Palette Snapshot, Presets Snapshot etc.
    It then might be worth making macros to recall each of these Snapshot pages, if you can't be bothered with MoreSK Snapshot no syntax!
    Hope that helps a bit.
    W
