ION 1.9
When I'm in global capture mode, it seems that the led in my capture button should be on. I've never seen it light up. (Maybe I have a bad button?).
- Steve Martin, Indianapolis Symphony
ION 1.9
Steve, I just checked this. If you enable capture mode (you need to press enter to confirm the capture enable mode), the LED should light. If that's not happening, please contact tech support.
a
I just realized that I wasn't properly entering capture mode (which explains some of the results I was seeing). I was failing to use capture twice on the command line. Sorry for the trouble.
- Steve
No worries. Glad it was that easy!
a
