Hello,
I use Absolute effects for rig checks, to run through all the parameters of each type of moving light, scroller etc. When the last step of each effect has been carried out, the effect then seems to restart itself, even though I always specify "Number of Cycles 1". After about 2 seconds of the effect trying to restart, it then stops itself and the lights revert back to where they've been told to be in the last step of the effect.
This has always been the case, it's not a new issue for me. I just wondered if this bothered anyone else out there? Or is there something I'm consistently doing wrong that could sort this out? It's not a massive issue, although the show I'm currently working on has Pirouettes and frankly, hearing them strain to go from Home, then CS, then Home again within the space of 5 seconds is painful! Should I be using a different sort of effect?
Further to the above, is there really still no way to put an effect onto a part? Or am I massively behind the times here?
Many thanks,
Jane
