After a focus session there are alot of zeros on screen, is there a way of clearIng them similar to the SHIFT-CLEAR command on a STRAND 500 desk.
Ian
Ian
Ian,
If you're looking for a Shift-Clear replacement you could use Clear-Enter, which will remove the manual status of the channels. ie no longer red zeros.
You may also want to consider using the 'Sneak' command. which will restore a channel to it's background value. (assuming you don't have any active cues or subs this will be zero, also clearing the manual value.)
So, if you have channels selected [Sneak] [Enter] will restore those channels to their background levels.
Hit [Clear] first to make sure you have nothing selected then use [sneak] [enter] to get rid of all your red zeros.
Hope that helps
Graham
Thanks Graham the CLEAR-ENTER command was exactly what I was looking for, now Idon't have the first Q of the show fuull of zeroes. :-) :-)
Cheers
Ian
