How do I erase the NFP in a submaster? My sub runs a conventional channel and there are NFPs in another channel that I can’t delete. Thanks
Sorry, I have to ask: NFP? The Eos documentation and software has the term "NIP" (Non-Intensity Parameter), but I'm not familiar with NFP. Could you elaborate?
I'm sorry, I have learned it as Non-Fade-Parameters, but yes, it is NIP, Non-intensity-Parameter. I stand corrected. How do I erase/delete them from a Submaster?
The closest Eos has to non-fading parameters would be Snap parameters. Snap is a property for a parameter that you can apply in the fixture editor. This will cause a parameter not to transition following the fade time but rather to snap to its target level.
To remove a NIP or actually Intens parameters as well is the same:
Blind, Sub 1 Enter
Chan 2 At Enter (removes all parameters or channel 2)
Chan 3 {All NPs} At Enter (removes all Non-Intensity-Parameters of Chan 3)
Chan 4 {Color} At Enter (removes all parameters of the color category)
Chan 5 {Zoom} At Enter (removes Zoom information)
{AllNPs}, {Color} and {Zoom} are all softkeys on your screen. You'll find them in the CIA.
Yes, these are the commands that I was missing. Thank you.
