When using learn+load on any faderwing for a cuelist, i can make changes like go from last etc (on touchscreen). Trying do do the same thing on masterfaderpair: Chan 1 Go From Last - Error: Syntax Error
3.2.9.16 Programming wing Windows nomad
Thank you for your report. This is already written up as:
[EOS-52479]
[Learn] + [Master] does not post the target of the master fader on the command line, resulting in syntax errors when you use the config GUI
I will add a note that you came across this as well.
This was fixed in 3.3.5.
