Lightning!
In the past I've just put a couple of big lights full white and put them in a sub. Tech then just bumps to create a lightning strike.
I'd like to make the effect more pronounced by setting the big lights to bright white while simultaneously putting all active lights to zero just for the duration. Am I thinking macro here? Can I trigger a macro with a bump button on a fader.
The long command line sequence would be select active out. Chan 101 + 102 Full. And then reverse it all. but this would be way to kludgy.
