Bug in Macro Editor when using Y_Focus and the "Done" softkey
Hi there,
I have a few macros that set XYZ placement for focus palettes that copies the Y_Focus data from a single channel, and updates that across a range.
I have noticed that when I copy one learned macro to another macro, make a few changes to the focus palette numbers, and hit the Done softkey, my channel number and the Y_Focus keyword merge to create one keyword that is "Chan 421Y_Focus" instead of "Chan 421 Y_Focus".
I would like to attempt to edit these macros to clean up some of the mistake keystrokes, but every time I make an edit and use the "done" softkey, the above behavior appears.
Example of Learned Macro that functions correctly:
Example of copied macro, edited and then clicked "done" softkey:
Eos 3.2.9, this happens on IonXe20, Gio, and Nomad on Windows PC
Updated some verbiage for clarity and reasoning for posting
[edited by: eljacko129 at 10:53 PM (GMT -5) on Mon, Sep 30 2024]
