Edit a Magic Sheet fixture symbol
Is there a way in a Magic Sheet to change the display symbol (shape) of a fixture without having to make a new item?
  • Hi Dave,
    If I'm understanding correctly, you're wanting to be able to change the shape of a magic sheet object without losing all of your data within the object (target, command, text, layout, etc.). If so, that is absolutely an option!
    Once in the Magic Sheet editor view, you can select one or multiple objects that you want to change the shape of. From here, you can use the Change Shape option by clicking the arrows to the right. A popup will then allow you to select what shape you would like to use instead.
    A note:
    If you are using custom SVGs for custom fixture layouts, sometimes the scaling can get weird if the scale doesn't match the built in options.
    Hope this helps!
  • Hi Bill,
    Thanks for translating - that is exactly what I needed. Didn't notice the arrows, obvious now that I know.
    All fixed - Thanks for the help!
