magic sheet and multitouch faders
Hello,
i would like to use multitouch faders on a magic sheet and it is not available even if the sheet is locked.
multitouch is working on the "faders" tab but not the magic sheet.
Is it an expected behavior or do you plan to add this option (or not) ?
  • Can confirm this is still the case, Multi touch input works on the fader display, but does not appear to work on magic sheets, and frequently causes locked sheets to jump to a different zoom / position.
    It would be really quite nice on a nomad setup to be able to have multi touch behave the same on magic sheets, and / or to allow us to reduce the obligate window padding on the fader tab!
