Hi All does anyone have or can make the fixture profile for the chalet strike array 2c 25ch mode
thank you
thank you
I can see you already requested the fixture at ETC's Fixture Library Hub. In the meantime you should be able to use the profile you can find in this showfile. It's patched as channel 1.
If you don't feel comfortable using a multicell profile (which is how I created the profile) you can always use two channels, each of them a Generic > IRGBAW 16b. Just make sure you always leave a gap of one address after every second channel, since you'll not be able to access the control channel of the fixture.
thank you
You can also download the fixture profile from https://gdtf-share.com/. You will need to create an account (free) and then search for your fixture. Download and then import into EOS software. The one I found was uploaded by the manufacturer so should work. There are quite a few profiles in different channel modes there too. There are also a number of user uploaded profiles that you can try but for my money the manufacturer one is probably the most reliable.
Regards
Geoff
