Is there an easy way of getting FX rates to home to 100%
if I home all faders they all go to 0% including the fx rates, I want them to home to 100%
thankful for any insights!
Is this about regular subs with a fader set to Effect Rate, about effect subs or Global FX faders?
regular subs with an effect rate and global fx faders.
I can't reproduce this. I can only see the behavior for 2x or 3x faders of a global FX fader if the fader behavior was left as Master, which isn't doing anything anyway.
What software version are you currently using? If you want to share the showfile you can either do that here as a reply or send it to eos(dot)moderator(at)etcconnect(dot)com.
