Magic Sheet Symbols, Parameter and Category v3.2.10
The new parameter category field item is basically very fine, but
- it is not backward compatible, when you load a magic, which is done in 3.2.10, in 3.2.9 the Intensity is missing.
Maybe the Intensity should exist as an own field item like before.
- The number of fields is insufficient, 6 fields are definitely too little, especially when you use also parameters.
