On EOS 1.9:
If I have levels on stage from subs only (no active cue on stage) and make manual changes to those levels, [UNDO] does not restore the levels to the sub values- i.e.:
- Sub 1 is Ch 1 thru 10 at Full. Sub 1 is at Full (via fader).
- Ch 1 [OUT] (Ch 1 goes to 0)
- [UNDO] [ENTER] (Ch 1 does not restore to Full - its level disappears)
- [SNEAK] does not restore Ch1 to sub level
- If you give Ch 1 any level, then a [SNEAK] command will restore it to the sub level (Full)
It appears that the [UNDO] puts the channel into an undefined state, so that [SNEAK] doesn't know what to reference for its target level.
-Todd
