Does anyone know that to do if you record a cue and your lights go up to 35%?
moved to Eos forum from Hamilton Programming Project
[edited by: eos moderator at 10:54 PM (GMT -6) on Sat, Mar 8 2025]
What font color are the intensity values of those channels? I assume they're yellow, that would mean you have a sub up.
Press [About] & [Cue], the console will show the source of the values rather than the values. If you previously had yellow levels you'd now see "Sub x". Release the key combo. Then type [Sub] x [Out] [Enter].
