It seems that x [Recall From] [Select Last] does not work.
In a macro it could be very useful to use [Select Last][Recall From] [Select Last][Select Last] to copy data between the last two (selections of) fixtures.
Is there a workaround for this?
since [select last] will "delete" your input, made prior, you may only go with something like recording 2 temporarly groups.
 Something "similar" came up shortly here in the Forum. But the overall topic was a different.
Mirror Moving Lights
Hi! Sharp! This post was exactly how my question came up. But I can see many more use cases.
The question is whether “deleting the input” after [select last] is a bug or a feature ;-)
