What is the role of the button named Freeze?
[Freeze] can be used to freeze or unfreeze a running Effect.
It needs an [Enter] though!
If you just type [Freeze][Enter], every runnning Effect will Stop, no matter if recorded to a Cue, run Manualy, ...
The Manual says this:
Freeze Note: [Freeze] is used in the examples below. Element 2 and Element Classic users will need to use {Fader Control} {Freeze}. Ion Classic users will need to use [Fader Control] {Freeze}.
[Freeze] can be used to halt all effect activity on any active faders. To activate a freeze for only a specific fader, press [Freeze] & [Load]. There are two ways to remove the freeze command:
• Press [Freeze] & [Load] again for the specific faders to unfreeze the activity.
• Press [Assert] & [Load] or [Go] or [Stop/Back] for the specific faders to resume the activity. You may freeze and unfreeze effects from the command line.
• [Effect] [2] [Freeze] [Enter] - to freeze effect 2. Freezing a specific effect is different from stopping an effect. Freeze will stop the effect exactly where it is.
• [Effect] [6] [Thru] [9] [Freeze] [Enter] - to freeze a specified range of effects.
• When an effect is in freeze mode, you can use the same command to unfreeze:
• [Effect] [2] [Freeze] [Enter] • [Effect] [6] [Thru] [9] [Freeze] [Enter]
thnkyu mathilda
